Carb Gasket Leak?
- mgutjr
Carb Gasket Leak?
27 Jul 2019 11:41
I suspect that’s what it is, but want collective confirmation. There’s a slight leak on the side of my carb. You can see it in the photo. Float level seems to be fine; per float gauge. 78 KZ650.
I’ve attached some pics.
Re: Carb Gasket Leak?
27 Jul 2019 12:55 - 27 Jul 2019 13:00
Looks like you need some new bowl gaskets.
Keyster offers a Special rubber gasket for the bowls.
www.motorradbay.de/z650b-yfcg-27r_1-gask...de6152c595e3b02241d6
Last edit: 27 Jul 2019 13:00 by Scirocco.
27 Jul 2019 12:56
Is the fuel Tee leaking? Did you change the O-rings?
- Warren3200gt
27 Jul 2019 14:00
I like the Keyster gaskets. Soft and spongey feel to them.
- mgutjr
27 Jul 2019 16:49
Thanks, y’all. Gonna get some new gaskets. They’re worn. Yea, it was leaking on center stand. Pulled the carbs and cleaned them too for good measure.
- loudhvx
27 Jul 2019 16:55
I think if you can take another photo and shine the light just slightly above where it is in your last photo (good photo BTW), then you can determine if it might be the fuel pipe leaking.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Warren3200gt
27 Jul 2019 17:24
Reason for asking if it leaks when on side or center stand is because if it leaks when on the center stand and your fuel heights are correct its not going to be the bowl gaskets at fault because your fuel level is below that height. So logic would say fuel T O rings or conecting pipes O rings and its weeping down the carb side to the lowest point. I.e. the bowls making it look like bowl gaskets at fault.
The following user(s) said Thank You: mgutjr
