Mikuni BS34 issues and pilot plugs?
- Maccasgt750P
19 Jul 2019 04:58
Hi guys,
I have a 1982 Kawasaki GT750P (shaft) and I’ve recently had some issues with my carbs.
Firstly on inspection I’ve found a crack in the body. It’s up where the pilot plug sits so I’m not worried at this stage.... please see photo and I hope you agree.
Second, The 4th carb didn’t even have a pilot plug when I opened it.
Finally, I can’t for the life of me find replacement plugs! I guess I could make some out of ABS but does anyone have a better solution?
Cheers!
Macca.
Attachment not found
Cheers!
Macca.
- azman857
Re: Mikuni BS34 issues and pilot plugs?
19 Jul 2019 19:25
XS 650's '80 and later used these carbs. They have the plugs. Check with. Mike's XS.com . Ebay too
19 Jul 2019 22:45
Kawasaki used a hard polyester pilot plug w/O-ring on at least some BS34 applications. Pretty sure you can replace those hard caps with some more common rubber plugs that can be purchased on ebay and such.
- Maccasgt750P
20 Jul 2019 17:18
Thanks for your replies!
I’ll jump online and have a good look here and post the plugs I find so someone with the same issue has a solution.
Macca.
Macca.
20 Jul 2019 17:31 - 20 Jul 2019 17:31
I have seen some Honda carbs used the same plugs you Need but i don´t know the exact model and year but give it a try on Google.
Last edit: 20 Jul 2019 17:31 by Scirocco.
- Maccasgt750P
20 Jul 2019 22:39
For anyone who was interested I have bout these
rover.ebay.com/rover/0/0/0?mpre=https%3A...2Fitm%2F392270387433
I’ll let you know how they fit when I have them.
Macca.
Macca.
The following user(s) said Thank You: MrBean23
