pilot jet turns, but doesn't fall out
- SpecialGreen
12 Jul 2019 11:39 - 12 Jul 2019 16:52
EDIT: finally got my pilot jet out, but the jets are all pretty beat-up.
Where can you recommend for a carb rebuild kit for a '78 KZ400B ("Keihin 1209 RK13") ? It looks like I've got:
When I look at rebuild kits, I only see o-rings, a float needle+seat, a pilot jet, needle jet and the needle, and some kind of threaded adjust screw with a pointed end (maybe the air bleed screw). But I need 3 jets.
Also, while I'm asking, the "MAINJET,PRIMARY" (the one to the side of the needle jet) appears to cover a pressed-in brass tube, which pokes slightly up into the carb throat. It looks like pounding it out would probably damage it... should I just leave it in and try to clean it with a fine wire?
- PILOT JET,#35 (92064-1001)
- MAINJET, PRIMARY,#70 (92063-1002)]
- MAIN JET,2ND,#95 (92063-1001 (which is the needle jet)
Last edit: 12 Jul 2019 16:52 by SpecialGreen.
- loudhvx
Re: pilot jet turns, but doesn't fall out
13 Jul 2019 09:41 - 13 Jul 2019 09:42
The brass tube that goes into the carb throat is usually the main jet. If it goes to the center of the throat floor, it should be the one the main needle slides into. If that's the case, you should be able to push through from the top downward with something soft like a chopstick (wooden). It should drop out through the bowl.
That one need s to come out since they can sometimes be covered in scuz.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 13 Jul 2019 09:42 by loudhvx.
- Warren3200gt
14 Jul 2019 03:13 - 14 Jul 2019 03:14
Depends where you are, from the time stamp it looks like the UK in which case Allensperformance.co.uk. all the items they have are genuine parts.
Last edit: 14 Jul 2019 03:14 by Warren3200gt.
