- Thank you received: 8
Would GPz750R1 Carb fit on KZ750E?
- dpivas7
09 Jul 2019 05:55 #807227
by dpivas7
Current: '19 Harley Roadster, '72 XLCH, '84 GPz 550
Past: '84 GPz 550, '82 KZ750 LTD, '71 XLCH
Would GPz750R1 Carb fit on KZ750E? was created by dpivas7
I found some GPz carbs online that may fit on my 1980 KZ750E engine, but I am having a hard time figuring out what type the GPz carbs are.
Are they Mikuni BS34s? Would that fit on a KZ750E?
Thanks.
Thanks.
- Thank you received: 1656
09 Jul 2019 09:31 #807251
by martin_csr
Replied by martin_csr on topic Would GPz750R1 Carb fit on KZ750E?
The Kawasaki factory service manual lists Mikuni BS34 carburetors for the 82 KZ750-R1. I bet you can use the carburetors from any KZ750-4. From the diagrams at Partzilla they all use the same carb holders & airbox ducts.
- baldy110
- Thank you received: 512
09 Jul 2019 15:11 #807270
by baldy110
Replied by baldy110 on topic Would GPz750R1 Carb fit on KZ750E?
They are BS34 and will bolt right on.
