not reving over 2200 rpm
  • ric812
  • ric812's Avatar Topic Author
Re: not reving over 2200 rpm
05 Jul 2019 14:58
#807019
yes I have learned that lesson, They are completely apart and I need to get some carb dip. I had read that boiling in lemon juice or vinegar will work also , any thoughts? Also any information on the pilot jet sizes, going from stock # 45 to #50. and are the ones listed correct for a 1982 KZ750 CSR Twin? Dennis Kirk has them listed a s a possible fit but the match what I currently have taken out.
1982 Kawasaki KZ750M Twin CSR
  • baldy110
  • baldy110's Avatar
05 Jul 2019 15:03 - 05 Jul 2019 15:05
#807020
Those pilot jets you found will work but I'd stick with the stock 37.5. Bigger pilot jets can be used if you've put on pkd filters and a performance exhaust but even then I've only had to go to a 40.
Last edit: 05 Jul 2019 15:05 by baldy110.
The following user(s) said Thank You: ric812
  • Nessism
  • Nessism's Avatar
  • Away
05 Jul 2019 18:32
#807024
Lemon juice will turn the carbs dark. Never used vinegar, and don't see the point other than maybe saving a few bucks over the dedicated carb dip stuff.
  • TexasKZ
  • TexasKZ's Avatar
05 Jul 2019 18:42
#807026
Nessism wrote: Lemon juice will turn the carbs dark. Never used vinegar, and don't see the point other than maybe saving a few bucks over the dedicated carb dip stuff.
+1
  • ric812
05 Jul 2019 19:19
#807030
I have the carbs torn down to the only thing left is the throttle blades, do I need to remove thise before I dip the carbs? I plan on getting a can of berrymen or gunk cleaner. Anybody have any particular favorite carb dip?
  • Nessism
  • Nessism's Avatar
  • Away
05 Jul 2019 19:21 - 05 Jul 2019 19:24
#807032
Berryman's. And no need to remove the throttle shafts. Just shoot water into the crevasse around the shaft when you rinse after dipping.
Edit: this carb rebuild tutorial isn't for your exact carbs but it covers the BS Mikuni's in general. Worth a read... zeus.mtsac.edu/~cliff/storage/gs/Mikuni_...Rebuild_Tutorial.pdf
Last edit: 05 Jul 2019 19:24 by Nessism.
  • ric812
05 Jul 2019 19:30
#807035
Thanl you for all the help
  • ric812
06 Jul 2019 11:59
#807067
How long do I soakthe carbs in berryman, 30 minutes or longer like over night
  • Nessism
  • Nessism's Avatar
  • Away
06 Jul 2019 15:11
#807081
Soak until they are clean. Typically a few hours if the dip is fresh. I know some guys that soak 24 hours just to be safe.
