81 kz650 csr carb setting order?
- agrestixrock
15 Jun 2019 16:22
does anyone know the order to set carbs? ive been told theres a certain order to set the air fuel and itd be the same as syncing them but cannot find any order in the manual. im just doing the air/fuel mix now.
- Online
Re: 81 kz650 csr carb setting order?
15 Jun 2019 18:39 - 15 Jun 2019 18:40
Why would there be an order to setting the pilot screws?
Last edit: 15 Jun 2019 18:40 by Nessism.
The following user(s) said Thank You: agrestixrock
- agrestixrock
15 Jun 2019 19:40
thats what i was thinking. he said it was the same as setting the vacuum sync. just thought it could make sense i guess. just happy i got it running again. im getting a little popping here and there and its a little choppy on the top end but think once i get these set it should be tons better
