KZ900 Idling on 3 cylinders
- Robb2018
- 76 KZ900 73 Z1 A
11 Jun 2019 07:35 - 11 Jun 2019 12:19
Mt KZ900 is only hitting on 1, 2 and 4 when idling below around 2 to 2500 rpm. I switched out the plug with #4 and no change. As I advance the throttle it hits on all 4. I just had the carbs ultrasonically cleaned but haven't discounted a plugged pilot on that cylinder. I'm off to check on that now. Can anyone think of anything else that could cause this?
KZ900; Z1
Last edit: 11 Jun 2019 12:19 by Robb2018.
- zed1015
Re: KZ900 Idling on 3 cylinders
11 Jun 2019 08:15
Given that the plug checks out and the coil serves two cylinders the most likely culprit is a blocked or partially blocked pilot as you suggest.
Could also be an air leak on the inlet boot side or missing vac port cap which would delay that cylinder pulling fuel at low rpm's.
The following user(s) said Thank You: loudhvx, Robb2018
- Robb2018
- 76 KZ900 73 Z1 A
11 Jun 2019 09:09
Thanks, I just put the carbs back on and the pilot jet is clean and clear, squirted carb cleaner through it. Will check the vac port cap.
KZ900; Z1
- Robb2018
- 76 KZ900 73 Z1 A
11 Jun 2019 09:23 - 11 Jun 2019 12:22
That was it. I had been missing 2 vacuum caps when I was going through the carbs and had made a couple of them out of a 1" piece of hose blocked off with RTV and a tight fitting screw. The screw had fallen out on number 3. I'll order a set of the proper caps. It's running like a Rolex now. You guys are the best!
KZ900; Z1
Last edit: 11 Jun 2019 12:22 by Robb2018.
The following user(s) said Thank You: SWest, Barry1
