- Thank you received: 15
1983 Spectre 1100
- tthunderdan
Now I have an issue with the Spectre 1100. After I fill it up with fuel, after about 45 to 55 mikes on that tank, it starts cutting out like it is running out of fuel. If I flip it to reserve, the bike runs fine, and I get to the nearest gas station to fill it. I have gone alot more miles (near 100, I think) previously before switching to reserve on the Spectre. I have removed the fuel tap twice now and find no crud or anything amiss (that I can see). One thing I notice is the plastic fuel strainer that attaches to the fuel tap, it appears that the on position flow gets its flow from pretty high in the tank, with the reserve flow section being rather high up also. The strainer looks like new with no noticable issues. My question is, has any other owners of these bikes had similar issues, switch to reserve at 50 miles? Any ideas what might be the issue? The bike does not appear to be dumping fuel any point, starts, idles, and runs great. I don't remember how many gallons it took to fuel after switching to reserve at about 50 miles then topping it off.
The tach has been jumping recently, are the odometer miles an electrical input? And could they be erratic also? I thought the odo was a mechanical connection to the wheel, correct?
The speedo reads steady and appears to be correct...to 85mph anyhow...
Dan from Slippery Rock PA,
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
- Greybeard
- Thank you received: 26
Another possibility is the tap needs a rebuild.
1982 KZ1100 D-1
- M_a_t_t
- Thank you received: 41
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
- Thank you received: 2236
Either way, 50 miles to reserve is way too soon.
Is it the factory correct petcock for that year and model?
- tthunderdan
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
I wonder if it is possible that the main diaphragm or the vacuum hose has a tiny little pinhole leak that allows the valve to slowly close?
How many miles have you been able to ride on reserve?
- tthunderdan
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
- tthunderdan
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
- M_a_t_t
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
tthunderdan wrote: so a vacume issue would affect the reserve also? I will check the cap also. the bike is still rideable and i suspect it would run on prime position if need be...
The vacuum line pulls on the large diaphragm to allow fuel flow in both RUN and RES positions. When the engine is off so there is no vacuum, the valve shuts so there is no flow in those two positions. The PRI position bypasses that business so fuel flows all the time.
As Matt said, the next time you ride and it starts to act up, open the cap and see if that cures the problem. It is best to do that when the tank is not completely full. If that does not do it, try running on PRI. Do not leave it in the PRI position when you park it, just in case one of the float valves does not seal perfectly.
- tthunderdan
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
