Air filter
- Scottbob76
13 May 2019 02:11 #803769
by Scottbob76
Air filter was created by Scottbob76
Hello
Rebuilding a 440 ltd
Mine does not have an air filter and air box has maybe seen better days.
If I change to a couple of aftermarket cone filters or other kind will I have to change any of the carb settings
My knowledge is probably just enough to be dangerous
- Thank you received: 1656
13 May 2019 05:15 - 13 May 2019 05:24 #803772
by martin_csr
Replied by martin_csr on topic Air filter
Howdy. The KZ440 has CV carburetors which can be difficult to tune for individual pod filters & you'll probably need to rejet. Nebr_Rex seems to know quite a bit about the 440, so if you do some searches, your ears should perk up when you see any of his replies, especially in regards to the carburetors & pod filters.
Last edit: 13 May 2019 05:24 by martin_csr.
The following user(s) said Thank You: Scottbob76
- JR
- Thank you received: 448
13 May 2019 13:56 - 13 May 2019 13:58 #803821
by JR
Replied by JR on topic Air filter
A few people have made their own air box
Google "custom air box for KZ440 kzrider"
That should get you a good start.
Last edit: 13 May 2019 13:58 by JR.
