- Thank you received: 4
Air box Baffle??
- Calvin9819
12 May 2019 15:08 - 12 May 2019 15:09 #803729
by Calvin9819
Air box Baffle?? was created by Calvin9819
Hey guys, so i found a guy that had a box of parts for my 82 550LTD. I got the air box, awesome. But i got this plastic piece, an looked it up. Its' called an Air box baffle. Never heard of it, an since my bike didnt come with a stock airbox i have no idea where it goes, or if its even an important piece to have in there. i know you have to have the bracket pictured, but i dont know where the hell that goes either. Can anyone help me out?
Last edit: 12 May 2019 15:09 by Calvin9819.
- Thank you received: 1656
12 May 2019 16:30 - 13 May 2019 05:06 #803738
by martin_csr
Replied by martin_csr on topic Air box Baffle??
Are there any bolt holes in the frame below the rear of the fuel tank?
Some of the 70's 650 models have the same baffle & it's attached there.
The way the baffle & bolts are oriented in the 550 airbox diagram, I'd guess it fits the same as the 650.
Last edit: 13 May 2019 05:06 by martin_csr.
The following user(s) said Thank You: Calvin9819
- Calvin9819
12 May 2019 16:44 #803740
by Calvin9819
Replied by Calvin9819 on topic Air box Baffle??
ill need to check, the bike is at my work. What does the baffle even do? Doesn't look like it goes inside the airbox
- Calvin9819
12 May 2019 16:55 #803741
by Calvin9819
No eBay APP ID and/or Cert ID defined in Kunena configurationEdit, it isnt a baffle. this is what i found on ebay:
- Thank you received: 2829
12 May 2019 17:45 #803744
by 650ed
Replied by 650ed on topic Air box Baffle??
The following user(s) said Thank You: loudhvx, Calvin9819
- loudhvx
- Thank you received: 1616
12 May 2019 18:30 - 12 May 2019 18:30 #803745
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Air box Baffle??
That piece goes in the same place on a Kz550 that Ed showed on his Kz650. On a 550, it also helps keep the air filter holder down in front. On a 550, there was a metal clip that used the same bolts, similar to the metal piece you show in the earlier photo, and it would hold the accessory fuse box with a little rubber holder.
1981 KZ550 D1 gpz.
Other links.
Last edit: 12 May 2019 18:30 by loudhvx.
- Calvin9819
13 May 2019 15:30 #803828
by Calvin9819
Awesome, that solves that mystery haha. Thanks guys!
