KZ1100 LTD carbs alternatives
- ramshtain
26 Apr 2019 14:21
Hi,
I've recently bought KZ1100 LTD for restoration. And after more detail inspection I found that one of carbs body inside is broken.
Tried to look for other carbs on ebay, but they are very rear and available ones exceeds my budget in times.
Are there any alternative carbs from other models which can be used for my bike? Something not so rear and hopefully cheaper?
Thank you very much for help/
Re: KZ1100 LTD carbs alternatives
26 Apr 2019 19:09
The 1000 carbs are very similar if not identical. Maybe you can find just the individual carb you need? Good luck searching anyway.
