- Thank you received: 5
Throttle cables
- Quigleyje
03 Apr 2019 09:56 #801443
by Quigleyje
81/84 kz/zx550
Throttle cables was created by Quigleyje
Is an 84 kz550 ltd's throttle cable longer than an 84 zx550? The zx550 engine swap I did on my 81 kz550a I'm using an zx550 cable but it seems a little short.
81/84 kz/zx550
- Thank you received: 1656
03 Apr 2019 10:47 - 03 Apr 2019 10:47 #801446
by martin_csr
Replied by martin_csr on topic Throttle cables
Ltd handlebars are typically taller than the standard models, so the ZX cable is probably too short.
Last edit: 03 Apr 2019 10:47 by martin_csr.
The following user(s) said Thank You: Quigleyje
- loudhvx
- Thank you received: 1616
03 Apr 2019 13:57 - 03 Apr 2019 13:59 #801457
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Throttle cables
The Kz550A is the "Standard" model, as in non-Ltd and non-Gpz.. The Ltd models are either Kz550C, Kz550M, or Kz550F models.
The Zx550A, or course, is a Gpz, albeit the later Gpz.
The early Gpz's were Kz550D and Kz550H models.
The Ltd's usually have the longest throttle cable. The Standard's cable is normally much shorter than the Ltd, and the Gpz throttle cables are still a tiny bit shorter than the Standard's.
1981 KZ550 D1 gpz.
Other links.
Last edit: 03 Apr 2019 13:59 by loudhvx.
