34mm Mikuni RS on Built Gpz750
  • gpzman2000
  • gpzman2000's Avatar Topic Author
11 Mar 2019 12:07
#800184
I have an 1985 Gpz750 that has a built motor. Wiseco 810 cc Big Bore kit, Megacycle Stage I cams, Kerker 4-1 Exhaust, Accel ignition coils, along with a set of Mikuni RS34's.
I've read other articles that suggest the 34 Mikuni's are too much for a stock 738cc motor. However, I'm wondering if anyone has done a similar setup with a Gpz-based 750 motor. The Gpz 750 motor differs from the KZ in a few significant ways, like higher compression ratio, hotter cams (factory), and ported intake on the head.
I was thinking that with the stepped up GPz motor, has anyone done a similar build? and what kind of results?
thx.
  • baldy110
  • baldy110's Avatar
Re: 34mm Mikuni RS on Built Gpz750
11 Mar 2019 15:12
#800192
Carbs are to big. I have a KZ650 with the 810 kit, bigger cams, ported head 4-1 pipe and run the stock VM24's. Over the years I've tried the VM29, RS34's, BS34's. I finally wised up and went back to the VM24's, tuned them to my engine and haven't touched them in years. Bike runs fantastic. Bigger carbs does not ecuate into power.
  • gpzman2000
11 Mar 2019 15:53
#800195
Forgot to mention.. My '85 GPz 750 originally came with 34mm CV carburetors. Just a little larger than your 26's... However, the bike ran excellent with the 34 CV's.
I've had problems sourcing replacement parts for these carbs, which is why I bought the new RS34's. The bike starts, runs, and idles okay. I haven't had a chance to test it at freeway speeds yet. One thing I dislike about ALL Mikuni RS carburetors, is the infamous 'Slide Rattle' you hear at idle! I know this is true, because I have RS40's and RS38's on two of my Gsxr 1100's.... It never goes away... LMAO.
  • kawi810
  • kawi810's Avatar
11 Mar 2019 16:03
#800196
i been running this same set up for years .runs great
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
The following user(s) said Thank You: gpzman2000
  • ayeckley
  • ayeckley's Avatar
12 Mar 2019 03:36
#800215
gpzman2000 wrote: I've had problems sourcing replacement parts for these carbs, which is why I bought the new RS34's.
That’s odd. I’ve been able to get just about everything imaginable for three sets in the last couple of years from Partzilla. Granted, some of the parts are not cheap, but when all is added up still a lot less expensive than a set of RS’s (even used ones).
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1 aka GPz 750
1983 ZX750 A1
1973 CL350K4
1984 ZX1100 A2 aka GPz1100
1969 CT90
2006 Burgman 400
  • gpzman2000
12 Mar 2019 11:51
#800235
Kawasaki parts # 92005 and +92005-A , the fuel tee and fuel pipes that join the carbs - shows unavailable. even on partzilla.
However, I was recently lucky to find new aluminum ones on ebay. they were hard to find, but should be a permanent replacement for the stock carbs.
  • ayeckley
  • ayeckley's Avatar
13 Mar 2019 04:25
#800258
gpzman2000 wrote: Kawasaki parts # 92005 and +92005-A , the fuel tee and fuel pipes that join the carbs - shows unavailable. even on partzilla.
Ah, yes - those. I am using the aluminum replacements as well.
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1
1973 CL350K4
1969 CT90
2006 Burgman 400
