1984 ZN700
- lhemrick
1984 ZN700
28 Feb 2019 09:58
I have a 1984 ZN700 with CV type carbs. It is stock except I am using pod filters. The bike is sluggish when you get in the throttle and when coming off a high throttle position with the grip it takes it more time than normal to return to a proper idle. What could be the issue?
- ajsfirehawk
Re: 1984 ZN700
28 Feb 2019 10:08
CV carbs are notorious for misbehaving with pod filters instead of the factory airbox. You path of least pain is to reinstall the factory airbox.
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
83 KZ1100 LTD
18 Z900RS
23 Mach 1
Re: 1984 ZN700
01 Mar 2019 07:17 - 01 Mar 2019 07:19ajsfirehawk wrote: CV carbs are notorious for misbehaving with pod filters instead of the factory airbox. You path of least pain is to reinstall the factory airbox.
Exactly! See link below for additional info. Ed
www.kzrider.com/forum/11-projects/610068...ct-test-pilot#798670
Last edit: 01 Mar 2019 07:19 by 650ed.
- lhemrick
Re: 1984 ZN700
10 Mar 2019 09:52
OK here is a problem I have found. The carb slide on #1 isn't working at all. It won't move at all even on heavy throttle and its not stuck. I pulled the slide out and can't find any hole or crack. The passages from the top to the throat are open. What could be causing this?
Re: 1984 ZN700
13 Mar 2019 07:37
Hold the diaphragm up to a bright light and look very carefully. A few tiny pin holes is all it takes to keep the slide from working properly. Also, somebody may have stretched the spring or replaced it with one that is too strong.
Does the diaphragm seal perfectly all the way around?
When you tested to see if the slide was stuck, did it move freely? It doesn't take much drag to overcome the vacuum.
