Mikuni RS Series Carburetor for KZ750
  • dpivas7
  • dpivas7's Avatar Topic Author
14 Feb 2019 08:20
#798641
Okay, so I finally ordered a new (used) engine for my KZ750 LTD. I got a 1983 Kz750EE engine, not sure what exactly it came from, but it doesn't come with carbs.
I could take my carbs from my '82 KZ750LTD and put them on the '83, but I was wondering about these Mikuni carbs I found online. Are they any good? Does anyone have any experience with them?
They have the radial flat slide which I happened to read recently improves the throttle response (not sure why though).
Thanks!
Current: '19 Harley Roadster, '72 XLCH, '84 GPz 550
Past: '84 GPz 550, '82 KZ750 LTD, '71 XLCH
  • baldy110
  • baldy110's Avatar
Re: Mikuni RS Series Carburetor for KZ750
14 Feb 2019 17:28
#798681
What size, They are great carbs but bolting them up to a stock engine is useless.
  • dpivas7
15 Feb 2019 05:44
#798701
34mm size.
Would it still be useless if I don't have a good set of Keihin stock carbs?
  • baldy110
  • baldy110's Avatar
15 Feb 2019 08:24
#798714
Getting a set of RS34 carbs dialed in for a 750 will be near impossible. They were made for a highly modded 750 and up. I ran a set of RS36 carbs on my highly modded 1175 cc GPZ engine with ported head a big cams. The 36'swere to big I should have run the 34's. Look for a set of Mikuni BS34 carbs their easier to find and will bolt right up. What are they asking for the 34's?
  • zukdave
  • zukdave's Avatar
16 Feb 2019 10:11
#798778
If you are dead set on after market carbs a set of CR29's would be a better choice.
I run a set of RS38's on my cammed and piped ZRX1200 and they work great on that motor.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • carl66757
  • carl66757's Avatar
11 Jan 2020 22:05
#816949
I'm a bit confused on how you can't tune them? they have adjustable accel pump, and you can change jets. compared to a new set of keihin cr carbs its a ton cheaper...... im in middle of research to buy a set of something weather it be keihin or mikuni.
  • baldy110
  • baldy110's Avatar
12 Jan 2020 10:07 - 12 Jan 2020 10:09
#816966
They are very tunable but not on a small engine. Putting a big carb on a smal engine is asking for a tuning nightmare. You will have an engine that will have a hard time running in the lower rpm range so riding it around town will not be fun. The larger the carb the worse the vacuum signal is at low rpm so you end up chasing tuning issues. The opposite happens with a smaller carb the vacuum signal is stronger so the carb is easier to tune especially on a small engine. The 29mm smoothbores are a better choice. It's basic physics
Last edit: 12 Jan 2020 10:09 by baldy110.
  • carl66757
18 Jan 2020 15:12
#817380
well i ask that becuase the Keihin CV carbs are 34mm and they are stock on the 750?
  • baldy110
  • baldy110's Avatar
18 Jan 2020 18:58
#817397
You are correct the 750 did come with CV34 carbs but the CV carb has a huge restrictor in the throat, butterfly valve so it's going to act like a smaller carb. The RS34's function differently than the CV carbs. Using RS34's on a 750 is like like trying to get a set of CV40mm to run correctly on a 750. Your comparing apples to oranges.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
19 Jan 2020 10:34
#817447
Anyone run RS carbs with the accelerator pump rod removed, thereby disabling the pump system?
Just wondering what disadvantages may be had by doing that.
1982 KZ1100-A2
