Keihin / Mikuni cross reference
- peter_e
27 Jan 2019 13:18
I got a 1977 KZ650 B1 that I am working through. The guy I bought it from claimed he had rejetted it for pods and 4-to-1. Almost everything else he said he had done was a complete mess, so I have little faith in his carburation skills.
Anyway, it has 117.5 Mains, but the pilot jets seem to be Kehin (because of the star-like K on them) and the size stamped on them is 40. The carbs are standard VM-24 with the air-screw and are suposed to use the 22/210 pilot jets, OEM stock size should be 15. My question is, does anyone know how this K-40 jet cross-references to Mikuni sizes.
I have searched the web and read lots on places like Jets-R-Us. Found a lot on Keihin/Mikuni cross-referencing for mains, but not for pilot jets.
Thanks.
Thanks.
- Nebr_Rex
Re: Keihin / Mikuni cross reference
27 Jan 2019 13:43
I would install the correct Mikuni pilot jets.
That will eliminate any uncertainty as to the proper size.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- peter_e
27 Jan 2019 14:17
Yes. I intend to do that eventually. What I am trying to find out is where I am currently starting from. The OEM Mikuni 15 pilots will probably be too small for the current set up. I am slowly working my way back towards more or less stock airbox and exhaust, but still tracking down parts.
- Warren3200gt
27 Jan 2019 14:39 - 27 Jan 2019 14:40
650 b1running mikuni vm 24s, with 4 into 1 and velocity stacks, I have pilots plus 2 sizes and mains plus 1 from stock. Runs perfectly and pulls way beyond the red line.
Last edit: 27 Jan 2019 14:40 by Warren3200gt.
The following user(s) said Thank You: peter_e
- baldy110
27 Jan 2019 17:47
17.5 pilot jets and 110 mains for that combo. That should get you pretty close.
