KZ900 2 & 4 dont seem to be firing
- djbragg
18 Jan 2019 17:30
Kz900 1976 starts with choke on, wont idle and seems cylineder 2 & 4 not firing? Is this a valve issue or carb issue. Running dyna S ingnition?
Re: KZ900 2 & 4 dont seem to be firing
18 Jan 2019 19:00
You need three things to fire...compression, spark and fuel.
Have you done a compression test? If compression is OK then it's likely not a valve issue.
Are your coils properly hooked up? Left one goes to 1 and 4. Right one goes to 2 and 3.
Have you checked your plugs to see if you have spark?
If you have compression and spark then your problem is likely carburetor.
- baldy110
- djbragg
