ZN1100 throttle cables, one or two ?
- jljim
14 Jan 2019 17:19
My 1985 ZN 1100 frankenbike project had been put together with an earlier KZ front end. So it had a 2 cable throttle set up but the extra cable was just tucked down between the carburators. Partzilla shows 2 cables in the parts diagram, but my Kawasaki service manual seems to only show one. The picture of the carb rack from the bike shows no attachment point beside the idle speed screw. I have 2 right side controls from 2 different venders that were both listed as '84-'85 ZN 1100. One has 2 cables, the other has 1 ? Any z11 owners out there ?
1981 KZ650 CSR
1985 ZN 1100 LTD
1982 GS1100GL
1979 Puch Maxi ( sold to buy the 650 )
1987 GL1200 Interstate
1986 GL1200 Aspencade (parts donor)
1985 ZN 1100 LTD
1982 GS1100GL
Re: ZN1100 throttle cables, one or two ?
19 Jan 2019 10:46
The parts diagrams at Kawasaki.com ( I suspect Partzilla uses the same ones) shows two throttle cables, but the throttle assembly bracket shown in the carburetor diagram seems to be designed for a single cable. Curious.
- hugo
- '92 Zephyr 750
20 Jan 2019 03:30 - 20 Jan 2019 03:31
The parts supplier use the parts diagrams from the manufacturers, but it does not matter. If the carbs linkgage does not have the provision, you can not attach a second cable unless you change the carbs.
....in any case, the pull cable does all the work. The return cable is just for 'safety' in the very unlikely case the linkage spring breaks.....but cars (and older motorcycles) never had two cables when they had carburators...…..I believe all is because of the 'liability' of today.
Last edit: 20 Jan 2019 03:31 by hugo.
