Leaky carb boot
- ERIK814
Leaky carb boot
13 Jan 2019 16:00
I have a leaky carb boot. Determined this by spraying carb cleaner around it and heard an RPM increase at idle. There are not any cracks that I can see visually, but I have not pulled the boots of the bike yet. Are there any fixes that do not require buying / installing a new one or is it best just to get a new one?
1981 KZ 440 LTD Belt Drive (Late Model)
Re: Leaky carb boot
13 Jan 2019 16:17
There are no real fixes for those old brittle carb boots.
If the carb boots have porous areas buy it new, they will last for the next 10 years.
Re: Leaky carb boot
13 Jan 2019 16:27
Scirocco is correct; replace the carb holders. Over time they develop tiny cracks on the mating surfaces that cannot be seen with the carb holders mounted on the engine. Those tiny cracks may look like they are insignificant, but they really do let air enter the system when the throttle is closed or nearly closed. Folks have tried to seal them with all sorts of home remedies, but those remedies are only temporary at best. Replacing the carb holders with new ones is the only way to really correct the problem. Ed
Re: Leaky carb boot
13 Jan 2019 17:28
When I install carb boots I apply a little gasket sealer to the boot surface.
- ERIK814
Re: Leaky carb boot
14 Jan 2019 14:36
Thanks everyone - I'll purchase some new carb boots (sounds like it is necessary). One other question - I'm like 80% sure the leak is just in the right boot but should I just go ahead and replace both? Z1 Enterprises sells them two at a time.
Thanks again!
Thanks again!
Re: Leaky carb boot
14 Jan 2019 14:38
Replace both. If one is leaking a fair amount the other is leaking at least a little or soon will be. Ed
- ERIK814
Re: Leaky carb boot
14 Jan 2019 14:40
Both it is. Thanks again!
- slmjim+Z1BEBE
Re: Leaky carb boot
15 Jan 2019 06:25
Suggest you apply the thread penetrant of your choice (Liquid Wrench, Kroil, etc.) to the threaded fasteners holding the boots to the head now, so they can be soaking for a good long time. Repeat every couple of days.
If any of the screw holes in the head are open at the back (not blind holes), get some penetrant in those open passages too, as the greenish corrosion will likely have developed there also. That corrosion can act like a very effective thread-locker.
If the screws are cross heads, use quality JIS screwdrivers or JIS bits in an impact tool to remove them.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Re: Leaky carb boot
15 Jan 2019 07:40 - 15 Jan 2019 08:15
In addition to the penetrant I would tap tap tap the screws w wood block & mallet. the vibration should help to free up those fasteners which can be difficult to remove. don't pound the fasteners & do not use a sledge hammer.
Last edit: 15 Jan 2019 08:15 by martin_csr.
- ERIK814
Re: Leaky carb boot
15 Jan 2019 11:23 - 15 Jan 2019 11:25
martin and slm:
The thread on the carb holder fasteners are obstructed by the existing boots so how do you get penetrant to the threads? Do you just spray it around the boots and hope it makes its way in?
By tapping with wood / mallet, do you mean place the wood on the screws and then tap (i.e. tap the wood to push the screws further down into the hole)? I'd assume hitting them from the side could shear off the bolts and would not be good.
You mention the back of the screw holes (in the engine head) may be open and can be sprayed with penetrant -- how does one get to those holes to see if they are in fact open? Is there a way to get to them easily without removing the engine from the chassis? I don't have a lot of space to work with.
Also, I checked the service manual and did not see any info on recommended torque for the carb holder fasteners. So I'm guessing add a non-perm locking agent and tighten them firmly but not enough to break/strip the bolts?
Thanks.
Thanks.
Last edit: 15 Jan 2019 11:25 by ERIK814.
Re: Leaky carb boot
15 Jan 2019 11:35
I think the threads are 6M fine. If you have JIS screws you should hand tighten and can use a little blue thread lock, although it's not mentioned in the manual. If you have bolts or allen screws you should tighten to 70 to 80 inch lbs and also use a little blue thread lock. Any more torque and you risk stripping the threads in the manifold. Note that I said INCH lbs, not ft lbs.
- slmjim+Z1BEBE
Re: Leaky carb boot
15 Jan 2019 13:37
About all you can do is apply penetrant around the screw heads. It may or may not work it's way into the underlying threads.
What 650ED means is, to tap the head of the screw on-axis. Inserting a screwdriver tip into the head and rapping the handle on it's end like a punch. will accomplish the same thing.
The top screws for the carb boots on a Z1 are in blind holes. The bottom screw holes for Z1 carb boots extend all the way through the boss on the head. That opens the bottom holes opposite the screw head to atmosphere. We've seen those screws corroded into the holes so thoroughly from moisture entering the opening in the boss that the screw head twists off before the screw shaft begins to turn, because the shaft is locked into place from corrosion at the open end of the hole. We only mention it to maybe save you some grief. We're not that familiar with 440 heads.
If you examine the head in the areas where the boot screws enter their boss, you should be able to determine if any of the screw holes pass through their boss. If all the holes are blind you can only treat the screw head areas & hope for the best.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
