Kz400
- Unk0wn0utlaw
18 Dec 2018 16:36 #795385
by Unk0wn0utlaw
Kz400 was created by Unk0wn0utlaw
Hi first time on here but i just bought a 1979 KZ400 as a project bike and i pulled the carbs off and found a tear in one of the diaphragms. I've looked a lot but not finding any replacements is there any good carb swap options without using a split throttle cable but still using dual carbs. Any ideas???? Pls help
- JR
- Thank you received: 448
18 Dec 2018 16:49 #795386
by JR
Replied by JR on topic Kz400
See JBM in the US
jbmindustries.com
or NPR in the UK
www.nrp-carbs.co.uk/motorcycle_carburettor_diaphragms.htm
jbmindustries.com
or NPR in the UK
- M_a_t_t
- Thank you received: 41
18 Dec 2018 21:11 #795395
by M_a_t_t
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
Replied by M_a_t_t on topic Kz400
Do you live in the Ohio/Indiana border area? Me and another forum member were just talking about a 79 KZ400 on craigslist in that area. Coincidence or not, glad to see you here!
Matt
Matt
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
- Nerdy
- Thank you received: 412
19 Dec 2018 18:51 #795448
by Nerdy
Not really. In order to avoid using a split throttle cable, you would need to have carbs that are connected together in a bank like the OEM carbs. I am not aware of any such aftermarket options, but you might be able to use the carbs from another model. The KZ440 would be the closest but I don't know what you would need to do with the carb boots and airbox connections. (The 400 and 440 carbs are not good candidates for pods).
The most common aftermarket carb replacement (I think) is a pair of Mikuni VM30s. These are not cheap but they're the best way to go if you want to use pod air filters.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Replied by Nerdy on topic Kz400
Unk0wn0utlaw wrote: Hi first time on here but i just bought a 1979 KZ400 as a project bike and i pulled the carbs off and found a tear in one of the diaphragms. I've looked a lot but not finding any replacements is there any good carb swap options without using a split throttle cable but still using dual carbs. Any ideas???? Pls help
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
- loudhvx
- Thank you received: 1616
22 Dec 2018 12:46 #795551
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Kz400
To me, the early 400's using mechanical slides work well with pods... or at least they can be made to work as good as stock, and require a lot of tuning knowledge, but no more so than the diaphragm carbs. They are not simple carbs, but do work well with pods once tuned properly. The later ones using diaphragms are getting harder to find replacement diaphragms.
1981 KZ550 D1 gpz.
Other links.
