81 kz750 leaking gas out of carb and super high rev at start
- lowkeyfilmz
07 Dec 2018 12:43 - 07 Dec 2018 13:16
Trying to bring this machine back to life.
9 years ago I had a pro go through carbs and learn me and got them set.
I did a quick clean of carb and got a super high rev as soon as she started on her own fuel.
Took carbs almost completely apart and spent 7hrs on them. After roughly 4 hrs research on this very helpful site.
Diaphrams all good, properly seated and move freely after light pokish w 1500.
All jets soaked and blown through and can see light through.
Only 1 bowl has overflow tube inside.
1 plug has bad oring. ( getting one shortly) it was seated tight but plu was misshapped.
2 floats sit higher and may be a different make. (When installed with tang on bottom)
Far left diaphram had minor crack. I repaired w jb weld and wet sanded smooth. I was careful not to let debris in.
Needle seats have been polished w brasso and q tip.
Needles look good under magnifying glass.
When I put gas bottle on carbs on bench they did not leak. On bike they leaked.
Ive read the topics about setting tang /float hieght but am a bit confused.
I plugged 3 left vacuum plugs and ran right one to petcock w tight hose.
All needles move up in seats equally at about 2 mm.
Reassembled tightened boots and she started and idleded but was sluggish to rev down after release of throttle and gas was dripping out of #3 drain nipple and wet on air intake side. (The only bowl w overflow tube.)
Questions:
Should needle tang be touching metal needle holder?
Do these floats look like they are in correct?
With bowls off and floats on I put gas from bottle in and no needles leak untill i pull float up
What is easiest to understand method for setting float height on bench.
My thougts are attach bowls fill w gas from bottle, put clear tube on drain nipple and make sure gas comes up to 2mm below bowl mating service after bend in tube.
Seeing hopefully 1 bowl will jump out as wrong.
Questions:
Attachment not found
Last edit: 07 Dec 2018 13:16 by lowkeyfilmz.
- davido
Re: 81 kz750 leaking gas out of carb and super high rev at start
08 Dec 2018 07:55
Cant see your photos -You do not have permissions to access this page.-Make sure you have your head the right way round when working on the floats, it can be confusing sometimes if youve got the carbs upside down on the bench. I found the Clymer manual helpful for setting my float heights. It covered both the wet and dry method (wet method being more acurate )
I also had a problem with carb overflow which I traced to a faulty fuel tap (The vacuum type ) so maybe give that a look as well.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- lowkeyfilmz
- lowkeyfilmz
10 Dec 2018 15:20
Finally got it sorted. The throttle linkage between 2 sets of 2 carb bodies was not linked. Pia but i got it linked. Bench tested w tube and it looked good. Put it on bike and it started w no leaky leaky. Cheap petcock is not letting gas drain and missing 1 plug wire but off to a good start.
- lowkeyfilmz
