VM29 Choke enrichment tube damaged
  • djbragg
  • djbragg's Avatar Topic Author
13 Nov 2018 06:33
#793754
Will VM29 smooth bores still perform with one damaged choke enrichment tube. Tube is still there but has a crack in it and bent a little.
  • Warren3200gt
  • Warren3200gt's Avatar
Re: VM29 Choke enrichment tube damaged
13 Nov 2018 07:19 - 14 Nov 2018 01:16
#793757
Once the choke is off the tube has no function. So as long as the bike starts on 3 cylinder choke, which it should, it will be fine. It might be worth trying to put some kind of sleeve on it to cover the crack if poss?
Z1000J2 somewhat modified!
Last edit: 14 Nov 2018 01:16 by Warren3200gt.
  • Daftrusty
  • Daftrusty's Avatar
14 Nov 2018 15:49
#793799
Just solder up the crack. It supposedly can be done with just a normal soldering iron.
Try googling “solder overflow tube”
and read up on it.
  • Nessism
  • Nessism's Avatar
  • Away
14 Nov 2018 16:29
#793800
I tried solding those tubes before and failed. After that I followed this tutorial and it worked great
cx500forum.com/forum/general-discussion/...ube-raplacement.html
Used the dimple in the side of a threading die to roll over the end. For the choke tube you need to drill a small cross hole near where the tube plugs into the float bowl. Overall, it's quite a simple process.
