Kz1000 e1(st/shaft) 1979 carbs
  • Poncho23
  • Poncho23's Avatar Topic Author
06 Nov 2018 16:54
#793483
Hello, I recently bougth a bike and I'm not sure if the carburetors that came with the bike are the stock ones. It works good but still have doubts. I attach some pics so you can tell me what you know about.
Thanks for everything B) B)
  • baldy110
  • baldy110's Avatar
Re: Kz1000 e1(st/shaft) 1979 carbs
06 Nov 2018 16:59 - 06 Nov 2018 17:02
#793484
Not stock, your 79 came with the VM series carb not the BS.
Last edit: 06 Nov 2018 17:02 by baldy110.
  • loudhvx
  • loudhvx's Avatar
06 Nov 2018 23:40 - 06 Nov 2018 23:41
#793502
In addition to what Baldy said...
If I recall correctly, the 79 1000 E1 carbs have an accelerator pump, which can be eliminated with different jetting, to simplify the operation and make the carbs more consistent.
Last edit: 06 Nov 2018 23:41 by loudhvx.
  • Poncho23
09 Nov 2018 20:01
#793638
You're right, I checked according the carburetor model you say and I provably have the kz1000 J model between 81-83 . Mine is bs34 and it's supposed to be vm28. Does this affect the performance of the bike? I mean with this carbs I go "slower"?
  • hardrockminer
  • hardrockminer's Avatar
10 Nov 2018 05:43
#793644
Look on the front bottom right of your cylinder casing. Does it say 998 or 1.015? If the former then you have an '81 or newer bike. If the latter (1.015) then it's a '79 or '80.
  • Poncho23
11 Nov 2018 18:05
#793694
I know I have the e1 model (engine, shaft and other features) but the cabrs are from other model (maybe J 81-83) so I want to know if that gives me lower speed ???
  • hardrockminer
11 Nov 2018 18:21
#793696
Hard to say for sure. It depends on how the carbs you currently have are set up. To be honest, I'm not familiar with them at all.
I believe the original carbs were VM28SS with an accelerator pump under #2 carb feeding a small shot of gas when the throttle is first blipped. They were good carbs...I have a set on my KZ1000. Some people don't like them because of the accelerator pump. It was added to assist with meeting emissions regs in the late '70's. There were also "smog" ports on the front of the valve cover that routed exhaust gas back to the air intake. It was an ugly mess of hose that most riders removed at some point.
  • baldy110
  • baldy110's Avatar
11 Nov 2018 20:13
#793700
If set up properly those BS34 will perform just as well as the VM28.
The following user(s) said Thank You: Poncho23
  • Poncho23
14 Nov 2018 21:31
#793814
thank you very much for the info. I was thinking to get the stock carbs right away but instead of that I'll try to set the best I can mine and see how fast they could go. Who knows I may keep'em
