What size main jets should I be using?
- jadkins91
29 Oct 2018 06:59
Greetings,
I have a 1978 Kz650B with a stock air box and a 4 into 1 Vance & Hines exhaust. What size main jets should I be using?
1978 Kz650 B
1978 Kz1000
1981 kz750
1978 Kz1000
1981 kz750
- OKC_Kent
Re: What size main jets should I be using?
29 Oct 2018 14:50
Take a look at this, it's on this site. Since we don't know what you have in there now, you'll have to open the carb bowls and check.
kzrider.com/filebase/download/32-kz650-c...ing-guidelines-kz650
Cashion, OK
78 KZ650 B2 85,000+ miles
- baldy110
- jadkins91
31 Oct 2018 10:06
I thought 102.5 was the stock main jet size?
1978 Kz650 B
1978 Kz1000
1981 kz750
1978 Kz1000
1981 kz750
- Nebr_Rex
31 Oct 2018 17:46
Check your manual.
From memory I think the KZ650s were 92/95 mains.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- baldy110
31 Oct 2018 18:37
Wow I give you a straight answer and you question it. If you know the answer why ask the question?
- KZB2 650
01 Nov 2018 05:13
102.5 s should be what you have stock.... you probably should check first as stated........ Baldy's probably right as just the header doesn't need much ..... 105s at most.
Adding pods would change things and maybe need 107.5s and with my set up I used 110s to 112.5s.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- jadkins91
01 Nov 2018 10:02
Baldy- Im not questioning your answer i just thought that 102.5 was the stock size and since the header was added i asuumed that the jet size would need to increase. I'll try anything to get the bike running smoothe for once. When i bought the bike the PO had 120 mains installed and the bike would barely run. Since then i've dropped down to 112.5 and the bike will run good for about 20 minutes then start acting real sluggish. When i check the plugs they are black.
1978 Kz650 B
1978 Kz1000
1981 kz750
1978 Kz1000
1981 kz750
- loudhvx
01 Nov 2018 10:48 - 01 Nov 2018 10:50
I ran a Kerker for several years using stock jetting on a 550, so it is possible to run stock jets with a 4-into-1. It was a tad lean and would take longer to come off choke, but it really ripped on the highway. I have since rejetted differently to get slightly better cold-weather smoothness.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 01 Nov 2018 10:50 by loudhvx.
The following user(s) said Thank You: jadkins91
01 Nov 2018 14:58
Have you checked the fuel level in each carb?
- baldy110
01 Nov 2018 16:19
Everyone who doesn't know what their doing thinks when they add a header they must also run big jets. Not true unless you do other mods also.
- jadkins91
01 Nov 2018 16:36
Baldy,
Appreciate the help. There's a motorcycle shop close to my house that carries mikuni jets. Ill grab a set of 102.5's and put them in.
1978 Kz650 B
1978 Kz1000
1981 kz750
1978 Kz1000
1981 kz750
