Carb Problems
  • skyrabian
  • skyrabian's Avatar Topic Author
Carb Problems
18 Oct 2018 12:17
#792501
Hello; I have a 1982 KZ440A. I have had the carbs rebuilt recently. When I accelerate the engine and then let off the throttle, it takes an abnormal amount of time for the engine to return to idle. I have checked the carb linkage, the throttle cable and hand throttle and they are all moving freely and they return to idle position properly. What could the issue be? Thanks, skyrabian
  • Nessism
  • Nessism's Avatar
Re: Carb Problems
18 Oct 2018 12:56 - 18 Oct 2018 12:57
#792502
Air/vacuum leak. Most likely the rubber carb and/or airbox boots.
Last edit: 18 Oct 2018 12:57 by Nessism.
The following user(s) said Thank You: skyrabian
