'80 KZ440A Petcock not flowing fuel
- gavroyer
20 Sep 2018 10:21
The petcock on my 1980 KZ440A (LTD) doesn't seem to be flowing any fuel when the bike is running. If I start the bike and ride, it'll die after a few minutes, but I can set the petcock to Prime and drive it all over without issues. Is this a failed petcock? I thought they ususally failed "open" such that when they fail they leak gas into the carburetors.
1980 KZ440-A1 LTD
Re: '80 KZ440A Petcock not flowing fuel
20 Sep 2018 10:50 - 20 Sep 2018 11:11
Would check integrity of the vacuum hose from carb to petcock.
It's the vacuum being supplied to the petcock that's supposed to enable fuel flow through the petcock when the petcock is set in the ON or RUN position.
Where vacuum is being supplied to the petcock, but fuel still isn't flowing through the petcock as it's supposed to, the petcock might be clogged internally whereby normal operation of the spring-operated diaphragm is obstructed with grit, sand, crud or whatever. Sometimes the condition can be remedied by disassembling and cleaning the petcock internals. Other times, replacement of some internal parts may be necessary, in which event petcock repair kits are usually available through suppliers such as Z1 Enterprises.
Last edit: 20 Sep 2018 11:11 by Patton.
- gavroyer
20 Sep 2018 12:52
Thanks! I took off the gas tank and hooked up a vacuum line to the petcock and tried sucking on it. I get a couple drops of gas, but not a lot. I also replaced the vacuum line at the same time, just in case. I think I'll try taking it apart and cleaning it next; hopefully that helps.
1980 KZ440-A1 LTD
- ThatGPzGuy
21 Sep 2018 08:02
Take it apart and rebuild it. Do it right and it will last a good long while...
Rebuilding Vacuum Petcocks
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
