1420 carbs ????
  • buswelder
  • buswelder's Avatar Topic Author
1420 carbs ????
15 Sep 2018 08:31
#790910
hello people I am building a 1420 street motor for my bike, I wondered what carbs other people were running on similar setups
  • z1kzonly
  • z1kzonly's Avatar
Re: 1420 carbs ????
15 Sep 2018 10:27 - 15 Sep 2018 10:28
#790914
Uhm??
1 - it is a motorcycle
2 - it has an engine
3 - it runs on gasoline
Need more info!
Last edit: 15 Sep 2018 10:28 by z1kzonly.
  • TexasKZ
  • TexasKZ's Avatar
Re: 1420 carbs ????
15 Sep 2018 11:35
#790918
What setup? What does the shop that opened up the ports recommend?
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: 1420 carbs ????
15 Sep 2018 14:51
#790930
How big are your intake ports?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • buswelder
Re: 1420 carbs ????
16 Sep 2018 09:41
#790989
its a 79 kz1000 , I have not had any work done yet I have just bought a wiseco kit to put on, its a 13.5 compression one but I intend to change this as its too high for street really , its very much in the early stages of development just fishing for info before I start
  • TexasKZ
  • TexasKZ's Avatar
Re: 1420 carbs ????
16 Sep 2018 12:51 - 16 Sep 2018 12:54
#790991
Ok, so this will be a street bike, not a race bike.
You are right about the compression. Even at 11or 12 you will most likely need a stronger starter from a CB750. www.kzrider.com/forum/4-electrical/59153...starter-into-gpz1100
The cams, valves, porting and carbs need to be chosen together so they complement rather than conflict each other. For a street bike, you will likely want a really strong mid-rpm punch. The ports and valves will need to be sized and shaped to be optimal at that rpm range, and carbs to suit the rest. An experienced engine shop like Cavenaugh Racing or APE will have invaluable knowledge and experience in such matters.
Last edit: 16 Sep 2018 12:54 by TexasKZ.
  • TexasKZ
  • TexasKZ's Avatar
Re: 1420 carbs ????
16 Sep 2018 12:59 - 16 Sep 2018 13:05
#790993
Last edit: 16 Sep 2018 13:05 by TexasKZ.
  • KZB2 650
  • KZB2 650's Avatar
Re: 1420 carbs ????
17 Sep 2018 07:10 - 17 Sep 2018 07:21
#791034
Remember years ago Dale Walker building a 1385cc street bike and having a full article in either Cycle world or Motorcyclist..... Was always one of his biggest fans and fell in love with the bike...... things have improved a lot over the years but you might be able to find some info on that by googling it ? .......Ok I had that a little off looked on his site and it was in Hot Bike mag in 82 and was a 1394, 10.5 to 1 with stage 1 Toshi cams and 33mm smooth bores.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 17 Sep 2018 07:21 by KZB2 650.
