BS34 Idle mixture tuning
- loneagle
10 Sep 2018 07:08
I was wondering if the fuel mixture screws could be set using a dampened vacuum gauge with each carb done individually. Each one would be set to the highest vacuum reading. I don't hear well anymore and have difficulty with the changes in sound of the engine. Please advise and thank you!
'78 Kawasaki KZ 1000
'02 Harley FXDWG
'16 Harley Street Glide
'02 Harley FXDWG
Re: BS34 Idle mixture tuning
10 Sep 2018 15:09
I am not so sure about using a vacuum gauge, but you can use a good quality tach/dwell meter with the tachometer set to one of its lower settings, like 0-2000. If possible. With the tachometer, you will be able to clearly see the changes. The factory tachometer is not really sensitive enough for this.
- loneagle
10 Sep 2018 15:28
That's a great idea, I have an old tach/ dwell meter that may work. I'm not sure if it will be sensitive enough. I'll have to give it a try and see. Thanks for the advice!
'02 Harley FXDWG
'02 Harley FXDWG
- Gdailey2112
- 82 KZ1100D1
21 Jul 2022 16:44
not certain what wire I need to connect to dwell meter? i'm guessing the black from coil?
1982 KZ1100D1
