kz1000p - throttle cable to carbs pictures
- russ_alternate
31 Aug 2018 18:02
Hey there.
I had my carbs rebuilt, got new rubber for the carbs, etc. but when it comes time to putting the carbs back on the bike I'm confused. The main problem I have is not knowing exactly how the throttle linkage is routed from the handlebar to the carbs. I've tried it next to the frame within the gas tank and that seems to tight, and going through some of the frame seems logical but it's not really long enough as when I turn the handlebars to the left it seems to bind.
It's on a 1997 KZ1000p so does anyone have pictures or advice on the routing of the cable?
Much appreciated.
Much appreciated.
- JMKZHI
Re: kz1000p - throttle cable to carbs pictures
01 Sep 2018 06:45 - 01 Sep 2018 06:47
Is everything the same as before? exact same throttle cables. same handlebars. same throttle grip assy.
Last edit: 01 Sep 2018 06:47 by JMKZHI.
- russ_alternate
03 Sep 2018 10:51
Yes all exactly the same. Took them off now it's a challenge.
If I look at the KZ1000p motorcycle service cycle supplement manual it has a grainy picture saying to "route the cables as shown" with notes to be 'inside fork leg' and 'under frame braces'. Unfortunately I'm not sure with cable length so some pictures from anyone with this bike and the route shown would be great.
- ThatGPzGuy
03 Sep 2018 11:59
Mine is routed from the handlebar straight through the fork legs on the right side of the backbone to the carbs. I don't have a push/pull throttle. Just the pull...
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- russ_alternate
03 Sep 2018 17:51
Thanks - I'll try it and see if that gets it.
- russ_alternate
05 Sep 2018 15:05
Only way seems to be to the right of the forks and then on the right side through the backbone. Anything else seems wrong as it binds when turning handlebars.
Thx.
Thx.
