VM 28's
- 1000J
VM 28's
19 Aug 2018 19:59
anyone know of carb holders 34mm in and out to mount VM 28's to an 81 J head....wanted to swap the 36rs flatslides out
- zed1015
Re: VM 28's
20 Aug 2018 01:54 - 20 Aug 2018 05:57
To fit VM28's to the 'J' head you just use the carb holders from a 903 or 1015 motor which originally held VM26s or 28s, they are all the same.
These are the ones with the brass vac take off tubes attached and are a straight bolt on fit to the 'J' head.
They don't need to be 34mm in or out. just the size of the carb bore.
Last edit: 20 Aug 2018 05:57 by zed1015.
- 1000J
Re: VM 28's
20 Aug 2018 11:38
