Airbox from 74-76 on a 79 Ltd Kz400
- GusFu
07 Aug 2018 14:05 #788417
by GusFu
1979 KZ400 sort of cafe racer thing...
Airbox from 74-76 on a 79 Ltd Kz400 was created by GusFu
Hi All
I've got not air filters at all on my new (to me) 1979 KZ400H Ltd and stock airboxes are tricky to find. I can get one from the 74-76 D model but I wanted to know if that would fit the '79.
If not what are my other options?
It's going to get pod filters on in the short term to get it running but my mechanic suggests that it'll always be a sub-optimal solution.
Would velocity stacks be an effective breathing solution on the stock CV carbs or am i going to have to find some flat slides?
Any help much appreciated!
- Thank you received: 2072
07 Aug 2018 15:12 #788420
by Scirocco
Replied by Scirocco on topic Airbox from 74-76 on a 79 Ltd Kz400
PODS are a PITA to tune right!!!
- Nebr_Rex
- Thank you received: 300
07 Aug 2018 18:36 #788433
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic Airbox from 74-76 on a 79 Ltd Kz400
The early KZ400 has a different carb spacing compared to the late KZ400/440.
Do a search for custom air boxes. Some have had some success building their own.
As for jetting carbs for individual filters I have used the DynoJet kit for the KZ750 LTD[H].
You can do it piece meal and it helps if you are on good terms with your local Sudco dealer.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
The following user(s) said Thank You: GusFu
