RS34 Mikuni's on 77 Z1000
  • Z1000A1
  • Z1000A1's Avatar Topic Author
05 Aug 2018 20:13
#788293
I decided to fit some RS34's to my 77 Z1000. After installing the carbs I have a problem when fitting the tank in that the petcock is resting on top of the carby.
Will a Pingel petcock provide the required clearance?
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: RS34 Mikuni's on 77 Z1000
05 Aug 2018 20:42
#788294
Have you taken any measurement?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Z1000A1
06 Aug 2018 00:18
#788300
No not yet. I will have look tonight. The RS34's also interfere with the crank case vent filter. I am hoping they fit the same manifolds at the VM29's I took off as these look shorter than the billet manifolds and rubbers that came in the kit but I didn't check prior to installing the carbs as I wasn't anticipating any issues.
  • Nebr_Rex
  • Nebr_Rex's Avatar
06 Aug 2018 21:19
#788376
Should take the same carb boots as the BS34s.
My KZ1100B1 had the same petcock problem.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
07 Aug 2018 08:00 - 07 Aug 2018 08:13
#788394
LTD tank has a different fitment position for petcock. redline cycle has detailed instructions + pictures to remedy your problem, check him out.
Last edit: 07 Aug 2018 08:13 by 9er rider.
