- Thank you received: 2
tk27/26 choke rod ball
- khungerf
the ball is a 1/8 ball - I can find those.
The spring seems to be no longer available and I am not sure how it even stays in place.
1st) is anyone has a spare.. that would be great!
2nd if anyone is willing to measure their spring I will try to make my own.
Thanks!
Lee
-Lee
'84 GPZ550
- jayrodoh
- Thank you received: 27
Spring is part number 92081-1440 I don't have that carb sitting in parts pile otherwise I'd be glad to measure.
1982 KZ750-M1 CSR
- jayrodoh
Can you pull one from another carb to measure?
1982 KZ750-M1 CSR
- khungerf
-Lee
'84 GPZ550
- jayrodoh
1982 KZ750-M1 CSR
- khungerf
I will order one, that is worth a shot.
-Lee
'84 GPZ550
- khungerf
According to Partzilla the same spring (choke rod detent) SPRING,SHAFT STOP is on these bikes;
Kawasaki Motorcycle 1980 KZ550-A1 CARBURETOR ASSY (KZ550-A4)Kawasaki Motorcycle 1981 KZ550-A2 CARBURETOR ASSY (KZ550-A4)Kawasaki Motorcycle 1982 GPz - KZ550-H1 Carburetor AssyKawasaki Motorcycle 1982 KZ550-A3 CARBURETOR ASSY (KZ550-A4)Kawasaki Motorcycle 1983 GPz - KZ550-H2 Carburetor AssyKawasaki Motorcycle 1983 KZ550-A4 CARBURETOR ASSY (KZ550-A4)Kawasaki Motorcycle 1983 Spectre - KZ550-F1 Carburetor AssyKawasaki Motorcycle 1983 LTD Shaft - KZ550-M1 Carburetor AssyKawasaki Motorcycle 1984 GPz - ZX550-A1 Carburetor AssyKawasaki Motorcycle 1984 LTD Shaft - KZ550-F2 Carburetor AssyKawasaki Motorcycle 1985 GPz - ZX550-A2 Carburetor AssyKawasaki Motorcycle 1986 GPz - ZX550-A3 Carburetor Assy
-Lee
'84 GPZ550
- khungerf
I have a couple 1/8" balls and a couple springs to try.
I cannot for the life of me figure out HOW the spring will stay put. the 1/8 ball is loose in there - what would 'lock' things into place?
Thanks,
-Lee
'84 GPZ550
- loudhvx
- Thank you received: 1616
The spring is short. It has to be just long enough so the ball goes into the spring hole a tiny bit, but still protrudes.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- old_kaw
- Thank you received: 269
khungerf wrote: Still looking for anyone willing to measure the spring in their carb.. know it is bit of a pain, but you can get at from the top of the carb.
Jayrodoh already measured it and gave the part number too. You both probably posted at the same time and you did not see it. When I googled the part number it pops at 19.99 on eBay + $2.00 frt.. WTF? ANOTHER 50 cent part that we are getting gouged on. It looks to come in a package of 8, but this genius gouger is selling ONE for $19.99 . Much like the special o-rings that they are gouging customer on. Just like printing money, when it's almost 100% profit. I have lost mine before, but was fortunate to find them after totaly cleaning out my shed and sweeping the floor, then using a magnet to pick through the sweepings and thankfully found them all back.
He said they are 3 mmX7.8mm. You can cut down the length, but the diameter can't be changed. 3mm=.118". Just under the .125" diameter of the detent ball. The ball can be found at the mom-pop hardware stores. I could not locate the springs anywhere.
Just like printing money! lol These 3 o-rings cost me $15.85 shipped. A real bargain considering most vendors want ~10.00 each PLUS freight. Daveo spotted these for me last week for under 5 bucks each.
1981 Kawasaki Kz1000K1
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- old_kaw
loudhvx wrote: I think Jayrodoh gave details on the spring for a set of BS34's. Khungerf has TK27 carbs. They are totally different manufacturers, but there is a chance the spring is the same. He should at least try one about the same length.
They have a striking resemblence to the BS34's from the illustration in your post from 2016. It appears to be part number 92081-1440. ONLY 25bucks with FREE shipping on ebay..
kzrider.com/forum/3-carburetor/601982-tk...tk27-how-to-identify
