kz440 Jet Question
- Grcko
kz440 Jet Question
21 Jul 2018 08:18
First let me say I am new to motorcycles. I was comfortable taking the carb apart and cleaning it but need some help on jetting. The bike came with pods and 2-1 exhaust. I am putting the air-box on and the original 2-2 exhaust. I checked the jets and the primary says 78 on it and the the secondary say M108. I looked at the Kawasaki parts diagram and it says the primary was originally 65 and the secondary was 88. Are these the jets I need? Do I need to replace anything else to bring the carb back to original to work withe the air-box/ exhaust? Any help would be greatly appreciated.
As Always,
1983 KZ440
1983 KZ440
- Nebr_Rex
Re: kz440 Jet Question
21 Jul 2018 19:30
Check the needle also.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Grcko
21 Jul 2018 20:15
I will do that. Thanks.
So just change those to what the parts diagram says all should be back to stock on the carbs?
As Always,
1983 KZ440
1983 KZ440
22 Jul 2018 15:24
Typically, that is all that gets changed. Other than that, it will be a matter of fine tuning as per the manual.
- Grcko
10 Aug 2018 19:45
So I have the primary, secondary and needle jets now. I found one more though. Pilot jet. Will this need to be replaced as well. I can’t see any numbers on it with my glasses on and a lighted magnifying glass so I don’t know what it is.
One other question; is the needle for the needle jet suppose to be loose or tight in the vacuum cyclinder? They are loose right now and have some wobble.
As Always,
1983 KZ440
1983 KZ440
- Nebr_Rex
11 Aug 2018 06:41
I would replace the pilot jet to eliminate that unknown.
Your jet needle being loose it normal.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Grcko
11 Aug 2018 07:47
I figured I should replace it. Guess I don't get it running this weekend.
Thanks for the confirmation.
As Always,
1983 KZ440
1983 KZ440
