1977 kz1000-p
  • Jmansbar
  • Jmansbar's Avatar Topic Author
1977 kz1000-p
01 Jul 2018 13:17
#786234
I have a Vance and Hines sidewinder exhaust with no baffle and AirPods. I have accell super coils with 8.8mm wires with points at the moment but will soon be installing either the dyna s electronic ignition or dyna lll. The question is about the jetting of the carb, what size pilot and main. Also do I need to run a hotter plug?
  • TexasKZ
  • TexasKZ's Avatar
Re: 1977 kz1000-p
01 Jul 2018 23:12
#786273
You might be surprised by what you can find by searching the file base on KZR.
Hotter plugs not needed.
www.kzrider.com/jdownloads/General/Gener...Simple_Jet_Guide.pdf
  • old_kaw
  • old_kaw's Avatar
Re: 1977 kz1000-p
02 Jul 2018 14:03
#786301
TexasKZ wrote: You might be surprised by what you can find by searching the file base on KZR.
I never have had much luck with the search engine on Kzrider, BUT a google search on the topic pops a LOT of Kzrider links., among a lot of others.
1981 Kawasaki Kz1000K1
