- Thank you received: 2
Silly question...
- RLBuddi
23 Jun 2018 10:44 #785730
by RLBuddi
Silly question... was created by RLBuddi
While the tank is being prepped for paint, ...is there a way to run the fuel line into a gas can, using only gravity to feed carbs? Thanks!!
- Thank you received: 2838
23 Jun 2018 10:50 #785732
by Nessism
Replied by Nessism on topic Silly question...
I made a remote tank out of a piece of ABS sewer pipe with a cap on one end which has been drilled/tapped for a brass nipple. I put a hook on the top so it can be hung up after filling with gasoline.
- Warren3200gt
- Thank you received: 716
23 Jun 2018 12:33 #785736
by Warren3200gt
- Thank you received: 1656
23 Jun 2018 13:37 - 23 Jun 2018 13:37 #785745
by martin_csr
Replied by martin_csr on topic Silly question...
I use a plastic lawnmower fuel tank as an auxiliary fuel tank & bungee cord it to the frame with some brackets. The mower tank plastic is fairly thick & heavy duty.
Last edit: 23 Jun 2018 13:37 by martin_csr.
- Thank you received: 2236
23 Jun 2018 13:38 #785747
by TexasKZ
Replied by TexasKZ on topic Silly question...
- RLBuddi
24 Jun 2018 01:30 #785779
by RLBuddi
Replied by RLBuddi on topic Silly question...
So, it will feed off gravity, instead of the centrifugal pump?
24 Jun 2018 07:03 #785791
by martin_csr
What motorcycle is it? You mentioned carburetors in the topic post, so they would be gravity fed on any KZ. ie, no fuel pump with carbs.
- Thank you received: 2829
24 Jun 2018 07:06 #785792
by 650ed
What "centrifugal pump" ??? :blink: Ed
Replied by 650ed on topic Silly question...
RLBuddi wrote: So, it will feed off gravity, instead of the centrifugal pump?
24 Jun 2018 07:15 - 24 Jun 2018 07:18 #785794
by martin_csr
I'm a tad confused as well. The motorcycle he's been working on is a Spectre 1100, so it shouldn't have a fuel pump or not even an accelerator pump.
If you go with an auxiliary fuel tank of some sort, you can install an in-line lawnmower shutoff valve.
Keep in mind that there's a fire danger, so make sure the tank is secured properly so that no one can knock if off the work bench, motorcycle or whatever.
Last edit: 24 Jun 2018 07:18 by martin_csr.
The following user(s) said Thank You: RLBuddi
- padarjohn
26 Jun 2018 14:14 #785930
by padarjohn
Replied by padarjohn on topic Silly question...
I went with an auxiliary tank like the one linked to earlier. And I got a cheap IV pole like this one to hold it.
IV Pole
Worked like a charm.
IV Pole
