odd issue
  • menace
  • menace's Avatar Topic Author
odd issue
07 Jun 2018 13:41
#784746
weird issue bike runs and idles great when i start it cold. then after about 15 minutes i cannot get it to idle. i have new ape valve springs. they are all perfectly shimmed in spec at a temp of 80 degrees. that is the only thing i have changed on the bike other than stepping up the pilots. the reason i went a size up on the pilots is because after flicking the throttle the bike would die i had the air fuel screws maxed out. i went from a 17.5 then 20 to a 22.5 now i am going up to a 25 or a 30. i am not sure how to get passed this issue. any advice would be appreciated also i guess i messed with the timing a bit i am going to go back to where i was stoooock
i have pods 4 into 1 pistons and the cam springs.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: odd issue
07 Jun 2018 15:24
#784753
I would say check the cam timing first.
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • wiredgeorge
  • wiredgeorge's Avatar
Re: odd issue
08 Jun 2018 08:26
#784781
What bike? What year? Which carb assy? How the heck do you shim valve springs and what difference the temp? Stepping up from #17.5 (guessing Mikuni carbs of some sort based on pilot jet size) to #25-30 won't help your issue at all and will only see fouled plugs. VERY fouled plugs.
  • Warren3200gt
  • Warren3200gt's Avatar
  • Away
Re: odd issue
08 Jun 2018 09:40
#784787
menace wrote: air fuel screws maxed out
Maxed OUT will be lean, maxed IN would be rich. Assuming mikuni air screw carbs. Sure you went the right way?
Z1000J2 somewhat modified!
  • menace
Re: odd issue
09 Jun 2018 18:58 - 09 Jun 2018 19:00
#784874
I'm starting to think I am way too rich on the pilots. The higher i go the worse it has gotten. What size pilots do you guys run with a set of pods and a pipe? It is a 1977 A model kz1000 Vance an Hines uni pod filters with a 1075 kit 26mil carbs (stockers)
Last edit: 09 Jun 2018 19:00 by menace.
  • SWest
  • SWest's Avatar
  • 10 22 2014
