One carb leaking
- bikerguy
24 May 2018 11:58 #783953
by bikerguy
1979 KZ1000 LTD
——— Previous Rides: Seca 550, GS400, GS750, RZ350, XL 250, Hurricane 1000, ZX900, ZX-10, Shadow Spirit 750
One carb leaking was created by bikerguy
Hi. I have just got my "new" kz1000 LTD started (woo hoo!). However, it appears that when the gas petcpck is turned in the reserve position, one of the carbs leaks gas out of its hose. When turned in the on position it does not. I imagine the float bowl is stuck for that carb, but strange that it would poor only on reserve.
Anyone have any idea what may be going on here?
1979 KZ1000 LTD
- Thank you received: 2838
24 May 2018 12:55 - 24 May 2018 12:56 #783956
by Nessism
Replied by Nessism on topic One carb leaking
Petcock dumping fuel down the vacuum line when set to the Res position?
Performing the clear tube test as detailed in the factory service manual is a useful test to see what the float levels are like.
Last edit: 24 May 2018 12:56 by Nessism.
- bikerguy
24 May 2018 13:03 #783959
by bikerguy
Thanks I will try that
1979 KZ1000 LTD
Replied by bikerguy on topic One carb leaking
Nessism wrote: Petcock dumping fuel down the vacuum line when set to the Res position?
1979 KZ1000 LTD
