Carburetor Fuel Tee Refurbishing
- seanile
- let's try this one more time with feeling.
08 May 2018 08:24 - 08 May 2018 08:31
Hi all, I couldn't find a tips and tricks thread, so if there is one, mods, please direct me that way and we can delete this.
I've got a set of Mikuni bs34 carburetors, with fuel tees (aka fuel fittings or fuel pipes) that were worn down a bit and didn't come with any replaceable o-rings. The rubber sheathing around the metal interior was molded to resemble o-rings. Over time, these wore down and resulted in a less than snug fit. I googled around and found some replacements of various lengths, but many of them were aluminum and overpriced or just as worn out as mine and overpriced.
What I did was bought 4 o-rings per fuel tee, and cut the edge of the fuel tee's rubber sheathing off with a razor blade by rolling the tee under the blade. pulled that off and then slipped two o-rings on either side. the specific o-rings i bought for my fuel tees are O-Ring - 7.0mm x 2.0mm - Fuel Fitting - Viton, SKU: XVO-00700-200 @ Z1 Enterprises.
here's what it looks like. hopefully this helps someone down the road
1982 Kawasaki KZ1000K LTD
2014 Yamaha Bolt XVS950
Last edit: 08 May 2018 08:31 by seanile.
- ajsfirehawk
Re: Carburetor Fuel Tee Refurbishing
08 May 2018 09:20
Nice fix!
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
83 KZ1100 LTD
18 Z900RS
23 Mach 1
08 May 2018 09:23 - 08 May 2018 09:24
On my project bike i have refurbishing the fuel tees, (2 piece of three way fuel pipe fitting), with a short piece of shrink tube.
I have renew them a decade ago but they are beginning to leak fuel.
The rubber "dry out" and shrink if no fuel flows through the fittings over a long time period.
I put them in fuel over several days to swollen up again but with no success.
2" of shrink tube and a heat gun do the job in 5 minutes to get a no leaking fuel carb set!!!
Michael
Michael
Last edit: 08 May 2018 09:24 by Scirocco.
The following user(s) said Thank You: seanile
08 May 2018 09:41
I've seen where guys cut off the fake o-ring bumps, down to the metal and install real o-rings. Personally though, I get or make new parts.
08 May 2018 18:19
Can wrap the ridges with Teflon tape (white will work, but yellow is a little more fuel-proof) to tighten the fit.
