Which K&N pod/cone filters for the 81 GPz550 with stock carbs?
- hailwood1965
03 May 2018 09:12 #782768
by hailwood1965
Which K&N pod/cone filters for the 81 GPz550 with stock carbs? was created by hailwood1965
Looks like I bought a set of filters that are way way too large for the 22 carbs. Does anyone know what the go-to K&N pod is for these tiny carbs?
Wish there was a cheaper alternative to the K&Ns.
- loudhvx
- Thank you received: 1616
03 May 2018 09:41 - 03 May 2018 09:44 #782770
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Which K&N pod/cone filters for the 81 GPz550 with stock carbs?
After many years of using different pods, the Emgo style pods are my favorite. They are only about $7 each. No oil or cleaner to buy which adds a other 20 to 40 bucks to the k&ns. If you are in a dry dusty environment, though, the stock airbox with stock paper filter might be better for the motor.
39mm. You will need to rejet, or at least bump up the needle.
1981 KZ550 D1 gpz.
Other links.
Last edit: 03 May 2018 09:44 by loudhvx.
