ID plz
  • Bad Bryan
  • Bad Bryan's Avatar Topic Author
ID plz
26 Mar 2018 07:37
#780818
Hi All,
Before I buy a carb kit, I want to make sure I’m ordering for the right carbs. I believe I have a VM26SS on my 1977 A. See photos plz.
Attachment not found
TIA
Bad Bryan
  • kevski
  • kevski's Avatar
Re: ID plz
27 Mar 2018 13:24
#780902
They look like early 26mm carbs a pic of the inlet sides would be more informative.
  • DFIGPZ
  • DFIGPZ's Avatar
Re: ID plz
28 Mar 2018 13:21
#780938
Bad Bryan wrote: Hi All,
TIA
If you buy carb kits be sure to get the good ones from Z1 enterprises [ with new mikuni jets, needls etc ]
1984 750 Turbo
  • missionkz
  • missionkz's Avatar
Re: ID plz
29 Mar 2018 22:10
#780991
Before you buy a piece of crap carb kit... find out what, IF ANY, carb parts you’ll even need.
95% of the time it’s zero except bowl gaskets and only possibly, needle and seats... and even they can be polished out.
Do a little reading here before wasting money on junk from eBay.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • z1kzonly
  • z1kzonly's Avatar
Re: ID plz
30 Mar 2018 06:52
#780998
Later 26mm. You should have took a pic with the air adjuster needles coming out the bottom at the base of the bowl.
Those carbs were from 77 & 78 KZ1000.
good basic carb for stock engines
  • Nessism
  • Nessism's Avatar
Re: ID plz
30 Mar 2018 17:35
#781038
Agree with skipping the junk aftermarket "carb kits". Get new O-rings and maybe flow bowl gaskets and go through the carbs properly... members.dslextreme.com/users/bikecliff/i.../vm_carb_rebuild.pdf
  • DFIGPZ
  • DFIGPZ's Avatar
Re: ID plz
31 Mar 2018 06:55 - 31 Mar 2018 06:56
#781065
Like I said before if you use the good kits from Z1 enterpries you will be fine as they contain GENUINE parts but they also sell the lesser quality kits which are not good . I have done a few with the good kits and all was well. www.z1enterprises.com/catalogsearch/result/?cat=&q=nencho
1984 750 Turbo
Last edit: 31 Mar 2018 06:56 by DFIGPZ.
