VM24SS Jets -Too Lean?
  • jt1000
  • jt1000's Avatar Topic Author
14 Mar 2018 07:51
#780222
I’ll start by saying I know this will be trial and error, but wanted to get a decent starting point. I have a 1978 KZ650B with VM24SS carbs. Bike will have UNI brand individual foam pods (cylinder shape not tapered), and a Kerker 4 into 1, most likely without the baffle. Currently we have the stock #15 pilot and stepped up to a #105 Main Jet. My initial thought is this will be too lean. I’m in Arkansas so low altitude (+/- 300ft). Any thoughts on if I should bump up both jet sizes or start here?
1978 Kawasaki KZ650 B2
  • TexasKZ
  • TexasKZ's Avatar
Re: VM24SS Jets -Too Lean?
14 Mar 2018 08:11
#780226
  • KZB2 650
  • KZB2 650's Avatar
14 Mar 2018 08:18
#780227
I went 17.5s and 110s maybe 112.5s with the baffle in. Many including myself has went to the 5th clip on the needle (up from the 4th stock) too but then some have not.
I never saw much of a improvement at all by taking out the baffle and it always seemed to run a little worse down low. I like my comp baffle with no packing good sound and not too loud to piss anyone off.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • jt1000
14 Mar 2018 09:10
#780229
The 5th clip position is the last, correct? That didn't make the setup too rich?
  • KZB2 650
  • KZB2 650's Avatar
14 Mar 2018 09:34
#780231
Yes ....... mine seemed good but I'm hardly a expert...... you'll be running in warmer air maybe try the stock 4th for a while.
1978 KZ650 b-2
The following user(s) said Thank You: jt1000
  • kz650guy
  • kz650guy's Avatar
25 Apr 2018 23:00
#782389
17.5 idle 110 main 1.5 to 2 turns out on mixture screw number 4 clip always worked good for me make sure your valve clearance is good and no vacuums leaks at your intake boots and it should be fine
  • Svendsen
  • Svendsen's Avatar
25 Jul 2018 04:52
#787622
How did this go? I am having the same issue at the moment but I am on clip 3.
[img width=307,height=209]file:///C:/Users/andres/AppData/Local/Temp/OICE_16_974FA576_32C1D314_2128/msohtmlclip1/01/clip_image002.jpg[/img]
Z650/ gsxr600 Cafézaki
