lean drop method to adjust idle mixture screw for multiple carbs?
  • Zaddict
  • Zaddict's Avatar Topic Author
  • Enjoying my Zaddiction!
01 Mar 2018 21:54
#779633
So I'm familiar with the lean drop method to adjust the mixture screw for a carb. Basically it involves turning the screw in until the idle stumbles, then turning it out until you get the highest rpms at idle and then setting it somewhere in between (there are lots of variations on this theme). How is this supposed to be applied to banks of carbs? Should one use the lean drop method for each carburetor? The thing is we usually hear something like "turn the mixture screws out 2 turns" implying they should all be at the same setting, but if you use lean drop on each carb they may be at different settings. Any thoughts?
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
  • TexasKZ
  • TexasKZ's Avatar
Re: lean drop method to adjust idle mixture screw for multiple carbs?
02 Mar 2018 07:09
#779645
Setting them all to the same number of turns out is just a starting point. Fine tuning each carb is as you describe.
The following user(s) said Thank You: Zaddict
  • Zaddict
02 Mar 2018 08:54
#779652
OK, thank you, good to know. I read a bunch of threads on the lean drop method and never found mention of how to deal with multiple carbs. I wonder if people realize this.
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
  • Nessism
  • Nessism's Avatar
02 Mar 2018 15:01
#779662
I advise to set them all at 2.5 turns. Then tweak them in or out to achieve the highest idle. Many times you will see no difference in the idle when doing this so in that case just set them all the same. While you are at it be sure to vacuum sync the carbs too.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
02 Mar 2018 17:54
#779670
Colortune comes in handy when adjusting the fuel screws.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Shdwdrgn
  • Shdwdrgn's Avatar
12 Mar 2018 09:46
#780114
Nessism wrote: I advise to set them all at 2.5 turns. Then tweak them in or out to achieve the highest idle. Many times you will see no difference in the idle when doing this so in that case just set them all the same. While you are at it be sure to vacuum sync the carbs too.
Would you do the vacuum sync before or after setting the idle screws? I'm at a dead start, just got a new rebuild kit in the carbs, idle screws set to 2.5 turns, and the carbs are synced by eyeball. Finally got it to idle yesterday so now I need to start tuning...
1981 KZ1000-JK1
She's a beautiful mess, and I've made her all mine
