KZ750 Twin Fuel Screw Trouble Shooting
- jimbrickland
01 Mar 2018 16:54
Hello KZ Riders,
I have been tinkering with my '76 KZ750B over the winter. A couple weeks ago I got it to start with the kick and it idled pretty well. After that I cleaned the carbs, put some 50 size pilot jets , and put everything back together. I haven't been able to get it to start since I reinstalled the carbs, grips, throttle cable, etc. It seems to have spark, fuel, and compression but obviously something is missing. The kick is strong and the electric start feels good as well. That's why I am guessing it is possibly a fuel mixture issue...
I have read through some of the threads in the past about fuel set screws but I can't tell if I am setting them correctly. I can feel the spring engage but when I back it out a couple turns 1 1/2 give or take 1/2 the fuel mixture screw seems loose. I pulled the plugs and they are a little fouled so I am officially out of my depth. Any tips or tricks for finding a baseline? You guys are always incredibly helpful. Thanks for your time.
1976 KZ750B my one and only
1983 KZ440 LTD my one and only's one and only
Re: KZ750 Twin Fuel Screw Trouble Shooting
01 Mar 2018 19:02 - 01 Mar 2018 19:02
Is the bike stock or modded, and if the later what was done? Trying to understand the reason for the 50 pilots? What is the stock size?
Last edit: 01 Mar 2018 19:02 by Nessism.
- jimbrickland
01 Mar 2018 20:11
Hey Nessism,
There is a forum member who has regularly recommended 50's on the old twins. He says they'll run better. I thought for 7 bucks each I would give it a try. That is the only modification.
