Carburator adjusting
- 78customkawi
27 Jan 2018 13:47 #777871
by 78customkawi
Carburator adjusting was created by 78customkawi
I have a 78 kz750 twin with aftermarket cone filters and is straight piped. It idles fine but when throttle is applied it wants to cut out. Is even worse about cutting out when put into gear. Can anyone help me?
- Thank you received: 2236
27 Jan 2018 18:27 #777897
by TexasKZ
Replied by TexasKZ on topic Carburator adjusting
You should spend some time searching this site. There are several discussion threads on this very subject. What you will discover is that those carbs really do not like open pipes and individual air filters. You may never get it to run properly.
The following user(s) said Thank You: 78customkawi
- stratman
- Thank you received: 37
27 Jan 2018 19:09 #777900
by stratman
1981 KZ650 CSR
Replied by stratman on topic Carburator adjusting
Like TexasKZ said, pod filters present a major challenge and straight pipes further complicate matters. Unfortunately, it doesn't look like a factory airbox has any chance of fitting in that frame so you're probably stuck trying to make the pods work. If you search this site (and the internet) for info on pod filters, you'll have lots of reading material. Plenty of guys have made it work well enough, but it won't be easy.
I wish you luck.
I wish you luck.
1981 KZ650 CSR
- JR
- Thank you received: 448
27 Jan 2018 19:22 #777901
by JR
Replied by JR on topic Carburator adjusting
Pods can be made to work by re jetting (lots of info here) but an open exhaust will make it more difficult.
Be aware that some brands of cheap pods have a lip inside them which can block air jets on the intake side of the carb and no amount of rejetting will work. You should remove and have a look inside a pod. Good pods like K&N dont have that lip.
- Thank you received: 2829
29 Jan 2018 05:58 #777944
by 650ed
Replied by 650ed on topic Carburator adjusting
The absence of mufflers will create a problem since it reduces back pressure so much. There's a reason factory race bikes have mufflers even though they do not need to be concerned about noise. Good luck.
- davido
- Thank you received: 292
29 Jan 2018 07:32 #777963
by davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Replied by davido on topic Carburator adjusting
The alternative ( The route I took when faced with the same problem) is to take the bike to a tuners with a dyno bench. He will have the knowledge and parts to rejet your carbs and set up the bike for the best performance possible using your straight pipe and pods.
Itll cost (??) but it does away with the headache and the stabbing in the dark of trying to DIY.
(I had oversized pistons,K&N filters,a race pipe and no idea where to start with setting it all up. It now idles and runs all the way through the rev range with no problems. Well worth the money IMO.)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- 78customkawi
29 Jan 2018 21:47 - 29 Jan 2018 21:49 #778004
by 78customkawi
Replied by 78customkawi on topic Carburator adjusting
If i do a lollipop baffle on the pipes and make the carbs on a single pod setup will that help in any way??
Last edit: 29 Jan 2018 21:49 by 78customkawi.
30 Jan 2018 06:09 - 30 Jan 2018 06:13 #778012
by TexasKZ
IMO, the best way forward is either to take Davido’s advice, or search for builds where the poster claims to have figured it out and start with that jetting.
Be absolutely sure that the valve adjustments are at factory spec, that the ignition advancer is working properly, that the battery, coil and spark plugs are new or at least perfoming as new, and that the throttle cables are properly adjusted and operating smoothly, or you may end up chasing your tail trying to compensate for another problem by changing the jetting.
Those changes will alter the equation, if you will, but not necessarily in a way that makes finding the sweet spot easier.78customkawi wrote: If i do a lollipop baffle on the pipes and make the carbs on a single pod setup will that help in any way??
Last edit: 30 Jan 2018 06:13 by TexasKZ.
