- Thank you received: 2838
Mikuni BS CV Choke Plunger Boots
01 Jan 2018 14:48 #776818
by Nessism
Mikuni BS CV Choke Plunger Boots was created by Nessism
I'm finishing up a set of BS 34 Mikuni's and the choke plunger boots fell apart. Partzilla and Z1 want something like $14 each which is a ripoff in my opinion. Searching the archives suggests that at least some guys say the boots don't need to seal air tight. If this is the case I've got some Suzuki GS version choke plunger boots that are better than the ones I've got.
Any opinions on this?
- jdvorchak
- Thank you received: 50
01 Jan 2018 14:58 #776819
by jdvorchak
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
Replied by jdvorchak on topic Mikuni BS CV Choke Plunger Boots
That is a dust seal rather than a fuel/air seal so I say use what you have. I've put a few GS carbs in service with cracked boots and never had a problem.
John
83 KZ550M1
83 KZ1100LTD
Also own:
