Does this bike sound normal?
  • czentner
  • czentner's Avatar Topic Author
23 Nov 2017 18:16 - 23 Nov 2017 18:17
#774983
Hi guys,
The community here has been a great help in getting my non-running '84 GPz 550 find running. I had to order airbox parts and clean the carbs (several times) but now it will run and idle normally. I think.
Since I've never heard one of these bikes run before, I was hoping you could watch a short video and let me know if anything seems amiss. It sounds ok to me, but then I wouldn't know. The only thing I have not done is synch the carbs - the idle screws are all set to factory default of 2.5 turns out.
GPz 550 running
Last edit: 23 Nov 2017 18:17 by czentner.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Does this bike sound normal?
23 Nov 2017 18:57
#774986
Set the screws at best idle and sync the carbs.
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Nov 2017 18:57
#774987
  • kevski
  • kevski's Avatar
24 Nov 2017 12:06
#775020
Sounds normal, a bit of tweaking and it will run a bit smoother.
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Nov 2017 14:38
#775028
Be sure the valves are in spec.
