Me from Wales again....
- Badger1963
02 Nov 2017 08:42 #774128
by Badger1963
Me from Wales again.... was created by Badger1963
Diaphragms changed and running well... Found leak at throttle spindle into butterflies... Can I get new seals to sort this... Much appreciate you guys and all the help I've received, bike is 1981 kz440
- ajsfirehawk
- Thank you received: 89
11 Nov 2017 10:12 #774455
by ajsfirehawk
79 KZ650 SR
80 KZ1000 Z1 Classic
83 KZ1100 LTD
Z900RS
23 Mach 1
Replied by ajsfirehawk on topic Me from Wales again....
Hi Badger, glad to hear your bike is running well. The butterfly shaft isn't perfectly liquid/air tight If the bike is running well, what makes you believe there is a defect?
Do you have the stock airbox? If yes my suggestion would be to get the bike warmed up and shoot a couple short bursts of starting fluid at the shaft bushings and see if the rpms increase appreciably. If no I think you are fine. If you have pods on it it will be difficult to shoot starting fluid in the area without some of it reaching the pods and invalidating the test.
79 KZ650 SR
83 KZ1100 LTD
Z900RS
23 Mach 1
