Hi everyone from Wales in the UK...
- Badger1963
20 Oct 2017 11:30
I have a 1981 kz440 and was wondering if it should have two pipes connecting from back of air filter to the carbs, or just the void that is the air box?
- kevski
Re: Hi everyone from Wales in the UK...
20 Oct 2017 12:10
Picture would be handy, but sounds like breather tubes from carbs to air filter which is normal practice.
The following user(s) said Thank You: Badger1963
20 Oct 2017 12:42 - 20 Oct 2017 12:44
Click here >
www.kawasaki.com/Parts/PartsDiagram/143044/1981/KZ440-B2
Supposed to be two air intake hoses connecting the carbs to the air box.
Last edit: 20 Oct 2017 12:44 by Patton.
20 Oct 2017 12:43
If you mean the number 14073 in the diagram, then yes, you need a pair. The carb overflow hoses should be draped over the trans case and vented to atmosphere just in front of the rear tire.
