float setting
- lhemrick
float setting
17 Oct 2017 13:56
I have a 1984 ZN700 LTD Shaft that first I can't find a manual for. Till I do can someone tell me what the float height should be so I can try to get this thing running. Thanks!
Re: float setting
17 Oct 2017 14:06 - 17 Oct 2017 14:10lhemrick wrote: I have a 1984 ZN700 LTD Shaft that first I can't find a manual for. Till I do can someone tell me what the float height should be so I can try to get this thing running. Thanks!
Float height should be whatever results in correct fuel level as evidenced by the clear tube test (typically about 3 mm below the carb float bowl gasket).
Last edit: 17 Oct 2017 14:10 by Patton.
- jdvorchak
Re: float setting
18 Oct 2017 04:45
Patton is correct but to get you in the ball park try 21 MM from the base of the carb body to the bottom of the float as a starting point. I try to rotate the carbs so the float just contacts the needle for my measurement. Hint that will NOT be with the carb turned upside down, But rather an angle approaching full upside down. Also make sure the needle plunger is free moving and spring loaded part works prior to setting carb float. Then assemble the float bowls and check with clear tube. .
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
John
83 KZ550M1
83 KZ1100LTD
Also own:
Re: float setting
18 Oct 2017 05:29 - 18 Oct 2017 06:03
Before trying to adjust the floats, you should do the service fuel level check to make sure you actually need to mess with them.
Usually, the fuel level should be 3.0mm +/- 1.0mm below the bottom edge of the carburetor body. pg 312 of the chain drive pdf.
Manual. search eebbaayy for KZ750 shaft manual. get one thru at least 1984. there are several listed & one is pretty cheap.
Kawasaki manuals have a model application chart on the back cover, so make sure yours in on the list.
In the mean time you can probably use the chain drive manual as a basic carburetor guide.
750turbo.com --- Index. 1980-84 750-4 & KZ700. 1983-85 ZX750. pdf manual link near the bottom of the list.
yellow/gold cover w color wiring diagrams. get the one listed as ->> GPz750 Base Manual.pdf. good scans.
The one that says full english is a cruddy, photo-copied version. all files except the last one should be pdfs (not exe).
Last edit: 18 Oct 2017 06:03 by martin_csr.
